amp meter
oadkins
Registered Users Posts: 19 ✭✭
Why does my amp meter read the same amps on the negatave combiner as it does on the positive combiner. Thank You
The current flow is through the entire circuit, a closed loop, so it will read equally on both legs.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I have been reading that I should have neg side of battery bank connected to house ground how will this affect circuit. Thanks
Having the negative connected to the ground will have no effect on the circuit as the positive is isolated from the ground and negative.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 626 Discussion Forums/Café
