Inverter problem - Prosine 1000i/12 230volt
This is a long shot but I'm hoping that someone can help me.
I have been given a Prosine 1000i inverter which was removed from an emergency vehicle that had been decommissioned and was being scrapped. Unfortunately the remotely mounted control/display panel was not recovered with it, in its place is an adapter panel having a twin terminal block and a 4 core telephone type cable emerging from a grommet.
In trying to fathom out the purpose of these 6 connections I did get the inverter up and running powering a 100 watt lamp but do not know what I did and cannot repeat the trick.
Can anyone, please, advise me which connections to make simply to run the device, I do not need the display part of the control.
Thanks in advance for any help offered.
  • mcgivormcgivor Posts: 2,212Solar Expert ✭✭✭✭✭
    edited February 2017 #2
    Here's  the manual, you may find the information you need, didn't read it personally.
    1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery bank
