Solar CHarge Controller Question- shows fully charge when not.
mannj24
mannj24 Registered Users Posts: 1
I have purchased 2 solar charge controllers on Amazon- and both have failed.
https://www.amazon.com/gp/product/B01J0QCDWW/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 I have 3, 100 watt panels wired at 12 volts. And I have 3 100AH AGM batteries.
The last charge controller I bought - kept showing my batteries as fully charged, green light and stopped charging- however the battery bank was at 11.9 volts-- fully charge should be near 13 volts. So I bought another 30AMP solar charge controlerr- followed directions and when I connect the battery it shows FULL 100% CHARGE.. I check my battery with my meter- and seperate elec gauge and both show 11.9.
Any ideas? I am a newby at this- but it is a simple hookup- every charge controller I try- shows my batteries at FULL charge and stops charging, but when I check with a meter- the batteries are near dead at 11.9.
    Are your solar panels hooked up and it's indicating fully charged?
    Inexpensive charge controller can only have a voltage based reading of State of Charge. While charging the voltage is likely above the voltage representing fully charged (12.7 volts). Just ignore the light. If you have a meter you can measure the voltage with the solar panels connected and without and see the difference.
    ...someone made the brilliant statement that to fix the charge controller, just put a piece of tape over the light that indicates fully charged!
  • mcgivor
    With automatic voltage detection always hook the battery first, then solar. Are there any setting menus, you might have to set these to your particular battery type, it may have a low default to prevent damage as not all battery voltage requirements are the sams, just some thoughts.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,044 ✭✭✭✭✭
    Are your batteries New?, Old?, Toast?
