Can I do this?
Old Guy
Old Guy Registered Users Posts: 51 ✭✭
I have my system running great now I think thanks to the members here......
I originally purchased 4 panels but 2 are working great.
I would like to use the other two panels for something.  Are there any devices that can run directly from the panels with no controller?
I was thinking about a ceiling fan.  They come in 120v AC for homes and 12V DC models for boats and RV's and I would be good with it just running when the sun was shining.
With a 120V AC fan, could I just connect a inverter to the panel and run 120 to the fan or would the fluctuating current not allow this?
Would this work with the DC fan without hurting anything?  I got this idea from a small solar vent fan I have in the garage.  Its just a small panel and fan but its been working great for years.  It seems to be a regular 12V motor.
OR if anyone is running something straight from the panels or a panel/inverter setup I would like to hear about it.
    BB. Super Moderators, Administrators Posts: 33,431 admin
    If you can find a DC fan and drive it directly from the solar panels--That would be better. Note that DC brush motors do not last very long in continuous operation (brushes wear out in ~5,000 hours of operation or so).
    There is a "black box" that goes between a solar panel and a small AC inverter--As near as I can tell, the black box has a voltage comparator and a relay. When the solar array voltage drops below ~10.5 volts, it turns off the AC inverter DC input to reset the low battery cutoff, to allow the inverter to restart. (most AC inverters "latch" the low battery voltage error and require a person to restart).
    http://mwands.com/store/12-volt-suntaqe-pwb-inverter-controller
    And a youtube video:
    https://www.youtube.com/watch?v=kZ1BzbzdrGY
    I make no claims about how well this will work for your needs or MW&S.
    If it cheap enough for your needs--You don't have much to lose.
  • Old Guy
    Seems like a fan with a brushless DC motor would be perfect.
  • mcgivor
    You could add the 2 extra panels to your controller and use a small inverter to power the fan using excess power, what size are the panels, I forget.
  • Old Guy
    Renogy 100 watt
  • mcgivor
    edited January 2017 #6
    You can add the extra 2 panels to your system and use a small inverter, say around 300W  or less to power a ceiling fan whilst the sun is shining, it would be a simple  addition, no need to look for special products, around $150 could get a reasonable pure sine wave inverte, Samlex  are ok, check the host's store, don't get a modified sine wave, they will make the fan growl, not nice on a quiet day.
  • Old Guy
    Thanks again Mcgivor.... I'm still trying to learn about inverters and how they can make 120 volts from 12. Its witchcraft I say!!!  I just think thats awesome and I want to buy one and put some MONEY in it and see if it can multiply that as well.   :D
  • Estragon
    edited January 2017 #8
    Think of the inverter like a cashier making change. Two tens becomes four fives, but it's still twenty bucks ( less a commission in the case of an inverter). ☺
