Latest offering from Power Jack (ugh!)
softdown said:Everyone agrees that the 60,000 watt claim is likely ludicrous. It is a 24 volt inverter by the way.
A 750 mcm cable could possibly handle the voltage for several seconds? As memory serves....that cable has almost four times the mass of a 4/0 cable.
What kind of cable are used on electric chairs? They have to be huge.
Insulation handles Voltage
Electric chairs use voltage, the human body resistance requires more voltage, only takes 10mA to stop the heart
and from the intertubes:"The first execution used a voltage of about 1,700, although it was not officially recorded. The voltage has tended to increase over time and in the modern era the voltage is usually 2,000 to 2,200 volts at seven to twelve amps."
So get a step up transformer 1:10 hook it up to this Power Jack and finally there will be a use for it, an electric chair....... because it's doubtful it can do what they claim.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Doubtful indeed. Yet at ~155 pounds, it is likely to be quite powerful. Copper windings are not cheap.
Don't forget to look for the bag of sand, hear the Chinese are moving their real estate one bag at a time.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
At that price I highly doubt the windings are even made of copper.
It was $1000 at Amazon...seems to have disappeared. Don't think I have seen windings that are not copper.
My comment was sarcasm, but you never know.
Maybe copper clad aluminum.
This entire thread was meant to be on a sarcastic note, at least from my angle.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
mcgivor said:Don't forget to look for the bag of sand, hear the Chinese are moving their real estate one bag at a time.
And I think some clone brand of test equipment installed iron weights in their gear to more closely emulate HP gear in the 80's
softdown said:It was $1000 at Amazon...seems to have disappeared. Don't think I have seen windings that are not copper.
mike95490 said:mcgivor said:Don't forget to look for the bag of sand, hear the Chinese are moving their real estate one bag at a time.
And I think some clone brand of test equipment installed iron weights in their gear to more closely emulate HP gear in the 80's"we go where power lines don't" Sierra Nevada mountain area
UPS really outdid themselves this time. Appears to have been dropped about two feet. Look at the large bolt head at the bottom of the unit. Some of the racking busted loose. Weighs 102 pounds instead of 150. The coil is wrapped.....could indeed be aluminum instead of copper for weight and dollar savings.
Seemed decent enough until UPS got a hold of it. Electronics are often not built to be dropped. The handling was so severe that I wonder if the government got a hold of it.
Yes....I gambled on it for a few reasons.
Power Jack just won't quit!
this from eBay today
Same claim in a smaller box even looks same. Does anyone beleive that!
david
2 Classic 150, 2 Kid, 5 arrays 7.5 kw total 2ea. 2S6P Sharp NE-170/NE-165, 1ea. 12P Sanyo HIT 200, 2ea. 4/6P Sanyo HIT 200, MagnaSine MS4024AE, Exeltech XP-1100, 2 Banks L-16 battery, Rolls-Surette S-530 and Interstate Traction, Shunts with whizbangJr and Bogart Tri-Metric, iCharger i208B dc-dc buck/boost converter with BMS for small form lithium 8S 16650 or LiFePO4,
- 626 Discussion Forums/Café
