Q: Bypass charge controller?
VolcanoSolar
Solar Expert Posts: 56 ✭
So I'm all set to fire up my new system, but the display on my MX60 is not working, and I'm waiting for the replacement unit in the mail.
And boy am I impatient; given the holiday and the distance to Hawaii, it'll be middle of next week at the earliest.
Meanwhile -- any harm done wiring 72-volt arrays directly into the 48-volt battery bank?
Given that:
- one can short-circuit panels without harming them;
- the voltage will drop to that of the batteries until they're charged up;
- nothing is being driven off of DC power, except the inverter;
- I'll be monitoring the battery voltage to prevent overcharge.
Battery bank is 24 L16s; panels are 9 Kyocera 175-watt.
- Ted
Given that:
- Ted
Re: Q: Bypass charge controller?
Yes, you can direct connect .. no technical issues at all.
You must be the charge controller ... so disconnect when the batterys are full ( you can only do Bulk charging ) and disconnect at night to prevent the panels from draining the batterys. -
And you have to be very careful in disconnecting if done under load. DC can sustain some pretty good arcs. You should use a switch rated for the load and make sure that it is not near the batteries (hydrogen gas).
You could also do a little "diversion loading"--Electric heater on the inverter to draw power roughly equal to the panel wattage...
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
