output of my dr2424
i need help to find out what is my problems the output of my 2 dr2424 is low about 100 . i check all contact............2 dr2424/12trace225ah
Re: output of my dr2424
Doubtful both inverters are bad, check with another meter also mod-sine ( square wave really ) inverters don't measure well with meters -
Tosho
Be sure to use a meter that reads true RMS (root mean square) as other meters do not read modified sine waves properly. You are probably fine, that sounds about right for a meter that will not read true rms.
Larry
- 626 Discussion Forums/Café
