outback fan
petertearai
Solar Expert Posts: 471 ✭✭✭✭
.hi . it would seem that the internal fan on my fxr24 inveter is on continually . I have about 100 watts load on it .internal temps are tx = 40 deg c
fet = 37 deg
caps = 54 deg
has been like this fir days . .environment temps about 18 deg day and 12 night . maybe the cap temps . is thus normal??
fet = 37 deg
caps = 54 deg
2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
Is this a new? I know my Prosine will run the fan with a load of about 300 watts, pretty much continuously unless the ambient temps are below about 50 degrees (10 degrees C) I also know it will over heat with a load around this high without the fan. I had the fan go out a couple years ago.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Definately not normal for a 24V FX. Call Outback for a kit or RMA.
Oh yea, does it start a large load like a 1500 watt heater?"we go where power lines don't" Sierra Nevada mountain area
Thanks for replys . it is about a year old .will try the heat gun as a load on it . yesterday I ran the washing machine ( around 300 watts).. fridge also running fine (inveter fridge) so soft easy starting .. will phone the supplyer today .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
spoke to dealer . they say it needs a look at . so will disconnect after weekend and they say it should be a same day turnsround. .. so looking like my first power cut in over 10 years .. my neighbors on the grid however have many power cuts per year , as we are at the end of a spur line..2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
Seems like I have read that low batteries may contribute to the inverter fan turning on? I'm not sure though.
took inveter back to dealer . fet pwb replaced . now fets and capacitors report the same temp . 36 deg and 37 deg . tx reports 38 deg . .all good now . and all done quickly under warranty .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
