Effect of Solar Panel with SS-316 frame instead of Aluminium frame
ecaits
Registered Users Posts: 3 ✭
One of my project at Iceland, I need to use SS-316 frame to protect from corrosion, instead of aluminium frame in solar panel.
As there is difference in thermal conductivity of SS (50.2 W/m.K) and aluminium (205 W/m.K) as a heat sink in solar panel.
If I use SS-316 instead of aluminium, what will be the impact of it???
If this is a solar PV panel, I doubt it will make much difference. The glass - frame interface does not conduct much heat.
However, the thermal expansion would be different. you may want to look up the differences between glass - aluminum and compare that to glass - SS316.
Stainless should be a "better match" to glass vs aluminum:
http://www.engineeringtoolbox.com/linear-expansion-coefficients-d_95.html
- 626 Discussion Forums/Café
