Help about lifting solar panel to roof...
ChanChan Posts: 45Registered Users ✭✭
I have a 300W panel and is around 25kg, any idea on how to lift the panel safely and efficiently?
Thanks.
  • PhotowhitPhotowhit Posts: 4,707Solar Expert ✭✭✭✭
    I've just slide them along an extension ladder in front of me, If you are uncomfortable with that you could beg, borrow/rent scaffolding. It might surprise you, if you live at all rural, how many people have scaffolding. After I broke down and purchased some I had a couple people say they wish they had know. They could have lent me some.
    If you are talking multiple stories it might be worth asking at a rental place for a shingle lift, I would worry about them on a narrow lift, but I suspect you could devise some method to stabilize.
    Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites,  Midnite E-panel, Prosine 1800 and Exeltech 1100, ForkLift battery. Off grid for @13 of last 14 years. 1000 watts being added to current CC, @2700 watts to be added with an additional CC.
  • Dave AngeliniDave Angelini Posts: 4,021Solar Expert ✭✭✭✭
    Hire young people!  When I need the help there are always young people who will lift batteries. The H series solar panels are too big for one person so I avoid them. I also never go on a roof including my own. Arrays are best on the ground if you can.
    And as Photowhit said scaffolding or a backhoe.
    "we go where power lines don't" Sierra Mountains near Mariposa/Yosemite CA
     http://members.sti.net/offgridsolar/
    E-mail [email protected]
  • MarkCMarkC Posts: 174Solar Expert ✭✭✭
    My installer brought all the rails and panels in a horse trailer.  We backed it up right next to my solar shed roof, loaded the panels to the top of the trailer and then on to the roof.  Made a great work platform.
    3850 watts - 14 - 275SW SolarWorld Panels, 4000 TL-US SMA Sunny Boy Grid tied inverter.  2760 Watts - 8 - 345XL Solar World Panels, 3000 TL-US SMA Sunny Boy GT inverter.   3000 watts SMA/SPS power.  PV "switchable" to MidNite Classic 250ks based charging of Golf cart + spare battery array of 8 - 155 AH 12V Trojans with an  APC SMT3000 - 48 volt DC=>120 Volt AC inverter for emergency off-grid.   Also, "PriUPS" backup generator with APC SURT6000/SURT003  => 192 volt DC/240 volt split phase AC inverter.
  • Raj174Raj174 Posts: 643Solar Expert ✭✭✭✭
    edited August 2016 #5
    Like Dave said, I used young people to get my 12 300 watt panels up on a 9 foot high ground mount rack.
    3600W PV, MNE175DR-TR epanel modified, MN Classic 150, Outback Radian GS4048A, Mate3, 54.4V 207AH LiFePO4 no BMS, 4500W genset.
  • CosmosCosmos Posts: 12Registered Users ✭✭
    My wife and I have a great system worked out for us; we are both 60 plus, off grid, remote and rural.  No young people close by at all. We use our backhoe with forklifts mounted on the front loader.  We clamp a piece of 3/4 inch plywood to the forklift arms and load the solar panels on the plywood flat.  i never do more than three panels at a time to play it safe.  It is so easy to raise up the loader with panels.  Sometimes I have used 2 x 4's to bridge a gap if there is one and then just slide the panel to where you need it.  The backhoe is a Case 580 Construction King so we can raise the loader pretty high.  We do this for roofing material too.  So if you have access to a backhoe might want to give this a try.  We always go slow and easy and never rush.  If the wind is blowing, we do it another day.
    Home.  30 Kyocera 265 6MCA, FP2-VFX3648 (two FM80 charge controllers, FW-X240 transformer, MATE3, HUB10, FLEXnet DC, two 80A charge
    controll breakers, surge protector), Zomeworks (two-UTRF-168) 9 panels on each,  2 fixed pole arrays with 6 panels on each, 24 Rolls Surrettes S-1660 (2 v) for a 48 v battery bank, various MidNite circuit breakers, combiner boxes, Zephyr Power Vent, Hydrovolt, MidNite Solar surge protector for AC/DC circuits.  Honda generators; 800, EU2000i, EM3500sx, EM6500.  Generac 8000.
    Off road Jeep trailer M416 conversion.  4 Kyocera 40 watt PV panels, Outback FX 2012 MT, Trimetric 2025 RV,  4 Optima Blue Tops, 400 watt AirX wind turbine (12 v), Morningstar Sunsaver S20 w/LVD disconnect , MidNite battery capacity meter, various fuses,.
  • rdgoodsrdgoods Posts: 6Registered Users ✭✭
    Being rural, and fifty-somethings ourselves (aside from there being no young people available); I stood at the top of the extension ladder upon our single-story roof while my wife tilted the panels up to the ladder at the base, then she lifted the panel from the bottom while I bend over (holding onto the ladder of course) and grabbed the top of the panel and lifted it onto the roof. Being an off-grid system, we only had to do 5 of these (though BIG panels!). Once you're done, take two Aleve, a shower, drink a beer, and go to bed !
  • softdownsoftdown Posts: 1,904Solar Expert ✭✭✭✭
    I'm 58. Just carried four 75 pound panels over 50 yards then hoisted them unto the roof. Had a glass of cold water and a game of computer Monopoly in celebration. Takes about 18 minutes to win on the computer. Used to take 4 1/2 minutes with a high speed controller on a 1989 Sega set. What happened to technology?
