How does one balance 5 12-volt batteries in parallel?
barny
Registered Users Posts: 8 ✭✭
I have 5 12-volt lead acid batteries I want to hook up in parallel to my solar panels. I want to hook them up in a balanced manner but although there is information for hooking up 4, nothing specifically for 5. Here is what I have come up with:
Positive: 1-4, 2-3, 3 to inverter, 4-5
Negative: 1-3, 1-2, 2 to inverter, 3-5, 4-5
Am I doing this properly or is there another method? Thanks, Mike
This will apply to 5 batteries. Use method #3 but read the entire page as to the reasons why.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
This is for a 12 volt battery bank, correct?
The website littleharbor2 gave cannot be found, and yes, Bill, I am using 5, 12V lead acid batteries hooked up in parallel.
A little garbage at the end of the link. Try this
5x 12 volt batteries in parallel is not my favorite. But if have them, might as well try and see how it works for you (follow good wiring practices).
Thank you, littleharbor2. I found the page and looked at method 3 as you advised. I have one question about this setup. I understand that the cables have to be the same length, but how does one connect them externally before running the cables to the inverter? Thanks in advance.
barny said:but how does one connect them externally before running the cables to the inverter?
buss bars are the preferred method in an application like yours.
https://www.solar-electric.com/catalogsearch/result/?q=BUSS+BAR
Thank you, Aguarancher. For all the difference it will make, I may use method two. In the explanation of method three, they recommend using it 'for 8 or more batteries'. Cheers.
Which buss bar would you recommend - 5 battery cables + and 5 - and the cable to the inverter for each.
personally I would use method #3. buss bars are usually made of aluminum or copper. what type you use depends on what type of battery cables you use. pre-made cables imo are the way to go. call the store and they can recommend what is best for your application. i use copper buss bars.
You can buy premade copper bar or plate ground.buss bars from Storm Power. They used to sell raw bar and plate stock to make your own I did that and used S/S fasteners. But I don't see the option to buy bar or plate stock anymore; just factpry made components.Northern NM, 624 watts PV, The Kid CC, GC-2 batteries @ 24 VDC, Outback VFX3524M
@Mountain Don - your link is missing the colon after http in your link:
http://stormpowercomponents.com
Marc
I have it figured out - thanks everyone for your help.
- 626 Discussion Forums/Café
