What advantage to an outback hub?
Freewilley
Freewilley Solar Expert Posts: 228 ✭✭
Since I have become aware that one Remote Temperature Sensor is not enough, I am faced with purchasing two more or getting a Hub to have my three outback products managed by my Mate.
The Hub will cost $100 more, and I am wondering what I get for that....
I looked at the Mate manual and do not see what advantage there is...the one I can think of is that I could limit the amount of solar going into my bank with the mate. Currently when I isolate one string of my bank I limit the solar through settings on each CC...this is not always the most efficient way, but the difference is probably very small.
Anybody know enough about Outback to comment? I have applied to join the Outback forum but am still waiting for approval so I can post this question...
thanks!
Mate, VFX 2812, FM 60 & MX 60, 2 Full River AGM 400 6v, 1400 watt Solar Array, Yamaha 3000iSEB inverter gen
12 volt Flojet water pump
off grid summer home in northern Ontario
  • softdown
    softdown Solar Expert Posts: 3,819 ✭✭✭✭
    The Outback forum is about as exciting as a trip to the morgue....in my experience. I have the Outback MATE with all of the bells and whistles. Could be useful to a techie. I think you can check on things remotely? Which means that it can be hacked....
    If you buy everything that some of the pro$ insist that you need, you may be Chapter 11 in awhile. Just my humble .02 .
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,044 ✭✭✭✭✭
    It took me about a week or more to get approved on their forum. Pretty slow paced forum but their IS a lot of good reading in the archives from the many years they have been around. Once you get through that don't hold your breath waiting for any amount of activity.
  • Freewilley
    I have put this question up on their forum...but does anybody here have a hub and one FX?????
  • Freewilley
    The outback forum has not come up with any benefit to a hub, beside the convenience of using the mate for programming.
