Help about lifting solar panel to roof...
Chan
Chan Registered Users Posts: 45 ✭✭
I have a 300W panel and is around 25kg, any idea on how to lift the panel safely and efficiently?
Thanks.
    I've just slide them along an extension ladder in front of me, If you are uncomfortable with that you could beg, borrow/rent scaffolding. It might surprise you, if you live at all rural, how many people have scaffolding. After I broke down and purchased some I had a couple people say they wish they had know. They could have lent me some.
    If you are talking multiple stories it might be worth asking at a rental place for a shingle lift, I would worry about them on a narrow lift, but I suspect you could devise some method to stabilize.
    Dave Angelini Solar Expert Posts: 6,749 ✭✭✭✭✭✭
    Hire young people!  When I need the help there are always young people who will lift batteries. The H series solar panels are too big for one person so I avoid them. I also never go on a roof including my own. Arrays are best on the ground if you can.
    And as Photowhit said scaffolding or a backhoe.
  • MarkC
    MarkC Solar Expert Posts: 212 ✭✭✭
    My installer brought all the rails and panels in a horse trailer.  We backed it up right next to my solar shed roof, loaded the panels to the top of the trailer and then on to the roof.  Made a great work platform.
    3850 watts - 14 - 275SW SolarWorld Panels, 4000 TL-US SMA Sunny Boy Grid tied inverter.  2760 Watts - 8 - 345XL Solar World Panels, 3000 TL-US SMA Sunny Boy GT inverter.   3000 watts SMA/SPS power.  PV "switchable" to MidNite Classic 250ks based charging of Golf cart + spare battery array of 8 - 155 AH 12V Trojans with an  APC SMT3000 - 48 volt DC=>120 Volt AC inverter for emergency off-grid.   Also, "PriUPS" backup generator with APC SURT6000/SURT003  => 192 volt DC/240 volt split phase AC inverter.
  • Raj174
    edited August 2016 #5
    Like Dave said, I used young people to get my 12 300 watt panels up on a 9 foot high ground mount rack.
  • Cosmos
    Cosmos Registered Users Posts: 13 ✭✭
    My wife and I have a great system worked out for us; we are both 60 plus, off grid, remote and rural.  No young people close by at all. We use our backhoe with forklifts mounted on the front loader.  We clamp a piece of 3/4 inch plywood to the forklift arms and load the solar panels on the plywood flat.  i never do more than three panels at a time to play it safe.  It is so easy to raise up the loader with panels.  Sometimes I have used 2 x 4's to bridge a gap if there is one and then just slide the panel to where you need it.  The backhoe is a Case 580 Construction King so we can raise the loader pretty high.  We do this for roofing material too.  So if you have access to a backhoe might want to give this a try.  We always go slow and easy and never rush.  If the wind is blowing, we do it another day.
    Home.  30 Kyocera 265 6MCA, FP2-VFX3648 (two FM80 charge controllers, FW-X240 transformer, MATE3, HUB10, FLEXnet DC, two 80A charge
    controll breakers, surge protector), Zomeworks (two-UTRF-168) 9 panels on each,  2 fixed pole arrays with 6 panels on each, 24 Rolls Surrettes S-1660 (2 v) for a 48 v battery bank, various MidNite circuit breakers, combiner boxes, Zephyr Power Vent, Hydrovolt, MidNite Solar surge protector for AC/DC circuits.  Honda generators; 800, EU2000i, EM3500sx, EM6500.  Generac 8000.
    Off road Jeep trailer M416 conversion.  4 Kyocera 40 watt PV panels, Outback FX 2012 MT, Trimetric 2025 RV,  4 Optima Blue Tops, 400 watt AirX wind turbine (12 v), Morningstar Sunsaver S20 w/LVD disconnect , MidNite battery capacity meter, various fuses,.
    NEW 12/21:  Sold the Jeep trailer, so that's gone.  The Home system is I am redoing completely, retiring the "old" home systems except still using Kyocera solar panels, etc.  New permitted system:  roughly 16,000 watts of solar panels (54 panels, Kyocera and REC), spread out on 2 Zomeworks, 2 Powerfab pole top mounts, and a large Snap N Rack ground mount (8000 watts with grade beam footings)..  2 Outback 8048A with load centers, 4 Outback flex 100 charge controllers, 4 combiner boxes, multiple surge protectors, Mate 3s, HUB 10, FNDC, 2 Lynx 1000 amp bus bars, 6 Fortress E Flex 5.4 Lithium Batteries, Square D Stu 223 disconnect, lots of matched battery cables, circuit breakers, fuses, etc.  Still finishing ground mount, inspector said to finish system and then final, estimate 2-3 weeks, no anticipated problems going well.  Kohler 14kW RESA, Honda EM6500, etc.
  • rdgoods
    rdgoods Registered Users Posts: 6 ✭✭
    Being rural, and fifty-somethings ourselves (aside from there being no young people available); I stood at the top of the extension ladder upon our single-story roof while my wife tilted the panels up to the ladder at the base, then she lifted the panel from the bottom while I bend over (holding onto the ladder of course) and grabbed the top of the panel and lifted it onto the roof. Being an off-grid system, we only had to do 5 of these (though BIG panels!). Once you're done, take two Aleve, a shower, drink a beer, and go to bed !
  • softdown
    softdown Solar Expert Posts: 3,822 ✭✭✭✭
    I'm 58. Just carried four 75 pound panels over 50 yards then hoisted them unto the roof. Had a glass of cold water and a game of computer Monopoly in celebration. Takes about 18 minutes to win on the computer. Used to take 4 1/2 minutes with a high speed controller on a 1989 Sega set. What happened to technology?
