Adding optimizers to off grid system with mppt charge controller.
Shay
Registered Users Posts: 2 ✭
I have installed several off grid systems on boats. These systems consist of 3 to 4 250 watt panels connected to a mppt charge comtroller. All the systems suffer to some extent from shading. I am trying to design a system using panel mounted optimizers in order to improve overall production. Can dc optimizers be added between solar panels and mppt charge controller. I don't know how the mppt charge controller will behave with 4 optimized panels feeding it.
Hi Shay, Welcome to the Forum.
You are asking a good question. In general, it is a very good idea to contact the Charge Controller (CC) manufacturer for guidance. Some Optimizers can damage some CCs, as I read it.
As you know, if it is possible, try to run individual PVs in parallel to help reduce the power losses from shading.
FWIW, Vic
Don't know about other brand optimizers but Solar Edge optimizers are intended to work with Solar Edge inverters, period. I would like to know which other brands work for off grid.
- 626 Discussion Forums/Café
