Another new guy with questions
Ponea
Registered Users Posts: 2 ✭
I have 5-100 watt panels, a 30 amp pcm controller, 3 deep cycle 12 v batteries and a 2000 watt inverter. I had planned on running the whole system at 12 volts. The distance between the panels and the controller is a about 50 feet. I had planned to use 10 gauge wire
well if you switched to a mppt controller it be no big deal about the 50 feet, as you can run much higher voltage and the mppt controller charge you 12 volt batterys600 watts of solar panels,Epever 30 mppt , 2 PWHR12500W4FR battery's in 24 volt setup
Hi Ponea,
Running 5 pairs of #10 AWG will work. That will give you a 3% voltage drop which is normally acceptable.
However since you are paralleling more than 2 panels you need a circuit breaker on each positive line.
A combiner box would make that easy to do.
This is the combiner...
https://www.solar-electric.com/mnpv6.html
This is a Midnite PV breaker that would work well for your needs...
https://www.solar-electric.com/midnite-solar-mnepv-12-amps-circuit-breaker.html
If you could, let us know the battery specs just to be sure the system is balanced, i. e. Is panel wattage sufficient to charge a given size battery bank capacity in amp hours.
Good luck with your system
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
3-12 volt 51 Ah batteries gel type deep discharge
You have enough solar panel to charge the battery. Many types (but not all) of gel batteries are not well suited to solar applications because they can't handle large charging currents. What model and brand are yours?
btw, 2000 watts is a HUGE inverter for only 152 ah of battery at 12 volts.
- 626 Discussion Forums/Café
