My first solar project
andersondiaz
Registered Users Posts: 22 ✭✭
Good morning,
I've already started my small plant and wanted to share a photo taken of the peak of the day. yesterday was a full day with clouds and production has been achieved was through the holes in the clouds.
before yesterday was less cloudy and I got a 12kw.
so far I've only connected directly to the grid without any protection, so any suggestions are welcome
if you want you can see the data online:
http://microreplusweb.renesola.com/en-US/Account/Login
user: anderson_diaz@hotmail.com
password: qwerty
system data:
10 solar panels brand ToPoint 235 WATT + 10 RENESOLA MICRO INVERTER Replus 250A
password: qwerty
system data:
Re: My first solar project
It looks good, One would assume you have the proper size breakers on the array and combiner box ( if even needed on 10 panels ) are back feeding into another breaker on the mains. One also assumes you have a proper grounding on the array. You could put some lightening protection in if that is of a concern to you. They don't always work, but some consider it money well spent.
Don't know if you have a metering agreement with your power company, some meters may not give you any credit for what you produce and some will actually see your production as usage, so you get charged for what you produce with a smart meter. -
Re: My first solar projectandersondiaz wrote: »Good morning,
How are you grid connected without protection? -
The system is grounded and has a breaker.
yet I need to execute the contract net metering.
still do not have someone to do the installation diagrams for the authorization.
I have a meter that is analogous, only rotates back and stop counting. -
Re: My first solar projectandersondiaz wrote: »The system is grounded and has a breaker.
Good Luck and enjoy the savings. -
Andersondiaz:
My panels used to be monitored by microreplusweb.renesola.com, but all I get now is a page not found error. Does yours still work?
If not have you been able to monitor the output of your individual panels?
Thanks -
