Low amperage on 2 new panels?Can I test at the panels?
SolarLakeHouse2
Registered Users Posts: 16 ✭✭
Purchased 2 solar cynergy 150 watt 8.65 amp panels and running them into a epsolar 4215 mppt controller..running 12v system..I've adjusted the controller for my new 4 batts (flooded and 475 ah) I've cleaned the panels,have them straight into the sun and only get like 3.5 amp with two 8.65 amp panels? Wow..somethings wrong..can I test them at the mc4 connectors for amprage?expensive 3/4 amp batter charger at this time..damm
What is the SOC of the batteries? If they are fully charged I wouldn't expect them to accept more than 3 or 4 amps.
What batteries do you have?
Edit: I assume the two solar panels are in series (not parallel)... is that correct?
88%
Even down at 40 or 45% I never see more than 3.8 amps
How do you know they are at 88%? (by voltage, or by battery monitor, or by SG) --vtMaps
The 4215..has a soc status...now it's 9.9 amps..dang I'm happy..cleaned the panels,adjusted them and reset the controller
Why I'm in the beginner forums..keeping these things in the sun is everything..I have 6 more panels to mount on "direct tv" sat dish mounts on 2" poles
Sat dish backing plates work awsome..poor man's solar mounts
- 626 Discussion Forums/Café
