opinions on battery charger/desulfator
fauss
fauss Registered Users Posts: 26 ✭✭
Which charger/desulfator does everyone use? I will be charging two 6v 208ah GC batteries in series. I read a post on here that suggested noco chargers. I've looked at a variety of brands but I don't know anything about them.
Here's one I have looking at
http://m.ebay.com/itm/NOCO-Genius-G3500-6V-12V-Wicked-Smart-Charger-Maintainer-3-5A-3500mA-/191791927380?nav=SEARCH
Any input is appreciated.
  • vtmaps
    That NOCO is for small batteries.... I doubt that it could ever charge your batteries.  You need a charger that can put out at least 10 amps at charging voltages (and that would be a slow charge).  A 20 amp output would be better.
  • fauss
    Thanks vtmaps. Any suggestions?
  • fauss
    BB. Super Moderators, Administrators Posts: 33,440 admin
    Is this for an off grid system with AC genset for backup? Or connected to mains 24x7?
    Iota chargers (with IQ4 module/option) is not too expensive and have proved to be pretty rugged. There is a new SDC Iota family that I know knowing about (yet--claims to work better on gensets?):
    http://www.solar-electric.com/batteries-meters-accessories/bach2.html
  • fauss
    I'm powering a small shed used mostly on weekends. I could run about 100 feet of extension cord from my house for the charger. I also have an old 3500 ac generator. I'll have two 100w panels at first. I don't have ideal sun conditions so I need to be able to charge the batteries until I get more panels.
    The picture I took is where the panels would be mounted facing south. ( Sorry for the poor quality of the picture) There is a pretty tall tree that would really effect charging in the winter months. All this has nothing to do with looking for a charger but what the heck.
  • vtmaps
    fauss said:
    That is for starting batteries.  You need something for deep cycle batteries.  Look at the Iotas that Bill mentioned.
    edited June 2016 #9
    Regarding desulfators, if you design your system well and take good care of your batteries, a desulfator will not do much (had been one report that a desulfator's electrical noise confused an mppt charge controller and reduced its output).
    If you do not take good care of your batteries, in my humble opinion, a desulfator will not help.
    You will find some folks that LOVE desulfators.
    Your choice.
  • Mangas
    Take good care of the batteries. They are the most expensive component in a well designed off grid system.
    I decommissioned our desulfators some time ago.
    Chargers - even ones for starting batteries are better than no charger, and can be left on for a while longer.  They may not give a complete charge.
    Iota chargers - have a lower power factor, and will demand more VA from your generator.
  • fauss
    edited June 2016 #12
    I won't be charging with a generator unless the power was out for awhile. So about a 20 amp charger is fine?
  • fauss
    edited June 2016 #13
    Will this charger work fine running off my house. Only using a charger in the chance I don't have good sun for a couple days.
    208ah 12v lead acid battery
    Iota does work well... On gensets, because of the "poor power factor"--You have to be careful to understand the input needs of the AC supply and the output capabilities of the genset.
    The standard Iota--20 amp @ 12 volt supply on a small 900 Watt Honda eu1000i genset does work fine. A 40-45 Amp @ 12 volt supply requires a Honda eu2000i minimum.
    The new SDC version of Iota--Don't know anything about them to make a recommendation of "old" vs "SDC" choice (SDC are limited to 12 and 24 volt battery banks).
  • vtmaps
    (I'm not sure they make a 12 volt 20 amp charger)
    All the Iota chargers (including the new SDC units) have very high inrush currents... even their 12 volt, 15 amp unit has an AC inrush of 30 amps.
    Inverter type generators, generally do not deal with high inrush currents as well as conventional generators.  There are a number of reports of inverter generators not working with Iota chargers...  PF is often blamed (and rightly so), but I suspect part of the problem is the inrush currents.
  • fauss
    Are all the Iota "low end " changers able to float your batteries?I'm not able to find much info on the Iota 25 amp me-sbe.
    Getting old... Yes, there is a 15 amp and 30 amp 12 volt charger from Iota... I don't know (or remember) if the 30 amp @ 12 volts can run on a Honda eu1000i, but I think not (poor power factor of the Iotas).
