Wiring Fan to panel - Very basic question
shaundeane
Registered Users Posts: 3 ✭
Hi everyone - I have a 15w panel and I want to use it to move air through my woodshed to help the wood dry faster and more efficiently. Very very basic set-up, the panel to run a 12v fan when the sun is out and when it's not, no big deal. No batteries or anything like that. I got a nice 15W panel and connector kit but there is no connector for the two prong standard plug on the fan. Is there a junction box or converter I can buy or should I cut the plug off and wire direct? Been searching around but can't find an answer so far. Thanks for any advice. I am excited to be dipping my toes in...
Just solder the wire to the fan connector (or wire pigtails) and insulation with tape as needed. You are working with low voltage and current levels--No real danger here for shock (do make good connections, do not be careless--Your shorted solar panel will output ~1 amp into the short--If it was a "stray strand" of wiring that made a short--It could overheat and start a fire (rare/worst case example).
Note, if you solder the wiring--Soldered wire should not be flexed--The wire will tend to break at the solar joints (i.e., don't mount panel to roof and fan to building door--Where opening/closing the door will cause wire to flex at the solder joint and work harden the copper wiring).
Thanks Bill! I just gave it a quick _finger try" and while I can confirm that the panel is functional, I could not get the blades on fan to turn (they work when plugged in to AC). Perhaps the fan is too big but I kind of doubt it. I will play around - all part of the learning curve. Thanks for taking a few mins to try and assist.
A.c. Rated fan needs ac voltage/current (generally).
What is the rating label on your fan (there is 12 vac vs 12 vdc.
A 15 watt panel will probably drive a 12 vdc @ 0.5 amp fan reliably.
Thanks again, Bill. I'll search for a 12vdc fan
- 626 Discussion Forums/Café
