Bluesky 3000i charge controller not working
I have 4 Renogy  100 watt panels and 4 Trojan 31 agm battery with a bluesky 3000i charge controller not working after only 5 months.I disconnect and reconnect all it does is show r 2.5 then goes to battery voltage on the display. Can anybody help me out,and I tried to get a hold of bluesky,2 weeks and no contact from them
  • mike74820mike74820 Posts: 44Registered Users ✭✭
    1-760-597-1642 is the phone number on there web page maybe they can help you
  • HK91HK91 Posts: 2Registered Users
    Did that and email no response.
  • BB.BB. Posts: 27,914Super Moderators, Administrators admin
    Use a volt meter to check the voltages at the Battery and Solar Array terminals (directly on the screw/terminal block). It is possible that you have a poor electrical connection somewhere.
    Otherwise, you may have to look for a replacement controller(?).
