6Volt EQ help
2Guido
Solar Expert Posts: 62 ✭✭
I have 6v deep cycles powering my off-grid system I now need to desulphate them to get them back on track. Problem is I cannot find a charger (40amp plus) that has the extra voltage (7.5) needed to bring them back up and equalize. There are plenty of 12v chargers that also do an EQ, but not 6v. Can anyone share a link as to where to find these chargers or offer a better solution ?
Best to desulphate them sooner rather than later. Just hook them up 2 in series at a time for 12 volts and put a standard 12v charger with equalization.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
