Interaction of CFLs and inverter
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
I have noticed that one circuit in the basement, 3 9W CFL's from stairs to door, always causes the inverters fan to kick in.
Other circuits, with 5 and 7 of the same 9W CLF's, do not cause the fan to run... I am suspecting an increase of temp on the main board...
Any ideas as to the cause, the drives or ? in the CFL's ??
If you can use a Kill-a-Watt or clamp on AC current meter and measure the current... Many (some or all?) pretty much seem to have a very poor power factor (down towards 0.50)--Which means the lights can draw ~2x as much current vs something with a near 1.0 PF...
If you have different brands of CFLs--It is possible (I guess) that some have better Power Factor than others.
Another thing to try--Unscrew the bulbs on the circuit that appears to be drawing more power--Then look at the current/power supplied by the inverter. Is it possible that there is a phantom load you don't know about?
Possible short in the wiring?
I believe that the CFL is interfering with the inverter if the load is low.
Take 1 cfl out and replace it with an incandescent bulb. Now switch the 2 cfl's and the 1 incandescent bulb on. This may take care of the problem. It is not really practical for solar applications but may work.
Cfl's work with high frequencies and this may cause interference with the invereter,
Try and see if LED's would do better.
This is a stab in the dark, I wonder if the poor power factor of CFL's is causing the fans to kick on. One string may just have a really poor one in it.
Typically, cfls are about what, 0.5 to maybe 0.6 at best? When I switched to the GE or Osram/Sylvania's I got from the home supply store or even my grocery store, the Kill-A-Watt showed about 0.6 minimum to 0.7 pf.
It is an improvement, maybe not much to matter in the long run, but might be enough to keep your inverter's fan from kicking on?
westbranch said:I have noticed that one circuit in the basement, 3 9W CFL's from stairs to door, always causes the inverters fan to kick in.
Other circuits, with 5 and 7 of the same 9W CLF's, do not cause the fan to run... I am suspecting an increase of temp on the main board...Any ideas as to the cause, the drives or ? in the CFL's ?? -
CFLs are inductive loads. Some inverters don't like a lot of inductive loads. As mentioned, you can add one incandescent (or any other resistive load) in the string, and that should solve the issue. Adding too many CFLs can actually cause a strobe effect with all the lights blinking on/off.
- 626 Discussion Forums/Café
