Portable PV System
aviluck
Registered Users Posts: 1 ✭
For my university project this year my task is to implement solar technology onto a pedal bus, also known as beer bus or party bike in some places. However i need some help in determining the correct size of different circuit elements required. So far the battery pack is a 3 kWh, 48v lithium ion battery pack (was sponsored). There are 3 PV banks available to me to use with this project Bank A-369.8 W, Bank B- 355.8, Bank C- 334.3W. The Ioc= 6.3 approx. for the banks.
I need to select an MPPT as well as other circuit elements that would be required in such a set up.
I'm hoping I could get some help as I am new and kinda lost at the moment in the design of PV systems
Is there even a 48v charge controller out there for lithium?
Morningstar and Midnight both make high end charge controllers that can easily programmed to whatever you want.
You need to program your Inverter LVD for the cut-off of your bank
- 626 Discussion Forums/Café
