Wiring 24V Battery Bank and Solar Panels.
linnux
Registered Users Posts: 5 ✭✭
Hello,
I currently have a 12V solar setup at my off grid cabin and want to remove the older 600W solar panels and replace with 6 - 250W 24V panels to supply power to my 10 battery's. The charge controller is Midnite Classic 150 and will need to buy combiner box, breakers and 24V inverter. Everything inside the cabin is very energy efficient and at night the the battery bank only drops 2-3% - using a TriMetric battery monitor.
I'm wanting to change the 12V battery bank to 24V, but not sure about wiring. I have attached diagram of 24V setup, would this work?
Also about wiring the 6 - 250W 24V panels, could you wire 2 panels in parallel using mc4 t branch connector that each run 30V into the combiner box? Would require MNPV6 breaker box and 3 - 20 amp breakers.. The distance from the panels to charge controller is 15-20 feet. The panels maximum power is 250W - Vmp 30.10V - Imp 8.32A - Voc - 37.5V - Isc 8.87.
Any help would be greatly appreciated.
Thanks,
Garrett
Thanks,
Garrett
Sounds to me like you should SERIES wire 2 panels at a time and bring the 3 series wired strings into the combiner box (which then parallel's your 3 strings). You could also series wire 3 panels at a time for higher voltage but if you have a 3 string combiner already you might want to stay with the 2s3p for better efficiency.
Welcome to the forum,
I don't see the diagram you attached. You have 10 batteries and you want to reconfigure them to be a 24 volt bank... what batteries are they?
As littleharbor mentioned, 2 of those panels in series is the correct configuration for a 24 volt system.
What's wrong with the old 600 watt panels?
Two panels 24V in series would work, but would make the power going from panels 48V? This would be going into 24V bank would this configuration work better?
The batteries are Everstart 29DC wet cell some of the batteries are going on 6 years old, but I never drain them below 80-90% and use a BLS desulfator. Reason wanting to replace 600W panels for the lack of power to charge the 1,200 ah battery bank and is only capable of doing this on very sunny days - charging the batteries 3-4%. I hope by adding 1.5KW or 2KW panels would charge the battery's 12-18% day this would allow for those overcast days. Would like to get Trojans, but have to much invested for now.
Thank you for your help and sorry about the diagram not showing. Below is the 24V diagram. -
Your wiring diagram is fine (Inverter to opposite corners, charge controller to "other" opposite corners).
My only nit to pick is that you cannot use a Clamp Meter or Shunt Based Battery Monitor to measure the "net current" into/out of the battery bank.
In the end, "net current" to/from the battery bank is really all the battery bank "cares about". Is it getting charged/discharged/sufficiently charged every day. So the ability to measure the actual battery bank current is helpful.
So--If you put both inverter+charger on the same terminals, you can now put a large shunt (in the negative battery terminal to battery negative bus/common connection point) and have a nicer way to monitor the actual battery current.
Thank you Bill. I have the charger and inverter on the same 500 amp shunt monitors power going in or out.
- 626 Discussion Forums/Café
