Question about solar power in green house.
kienew
Registered Users Posts: 3 ✭
Hi all, just joined now. I'll describe my situation first. I have a 50w solar panel, my plan is to put it on my greenhouse to power my irrigation system, running into a 20a 12volt to 240v solar charge controller, then to one batter and an inverter to power a small 12v pump on a timer. But I also have a peltier module kicking about somewhere. So this is my question.... Can I wire the module into my solar charge controller? I'm really new and a novice this idea with the solar panel only started 2 days ago when I was given a solar panel. And the peltier module I got a few months ago for my daughters project. Thanks Kieran.
Welcome to the forum,
You are very confused.kienew said:running into a 20a 12volt to 240v solar charge controllerkienew said:then to one battery and an inverter to power a small 12v pump on a timer.kienew said:I also have a peltier module kicking about somewhere. So this is my question.... Can I wire the module into my solar charge controller?
Hi ignore the 12 volt part I was a little confused there. I wanted to use an inverter so I could plug maybe a radio or any other appliance in when in the greenhouse. And the peltier module part was just out of curiosity as it puts out voltage so I was thinking it could be connected to a solar controller to charge a battery without over doing it if I forget it's connected for say a week. This is all really really new to me but I find it really interesting please don't take my ignorance as insult. Thanks.
Most people way over estimate how much power a solar system can supply and underestimate how much power they will use.
Also--To keep things easier to follow--Ask one set of questions on a specific project first (such as water pumping) and then ask about unrelated project (say Peltier module) second.
A 50 Watt solar panel in London England will (on average) see this amount of sun:
http://solarelectricityhandbook.com/solar-irradiance.htmlLondon
Measured in kWh/m2/day onto a solar panel set at a 38° angle:
Say you start planting in March--That is (on average) 2.76 Hours of sun per day:Jan Feb Mar Apr May Jun 1.27
2.04
2.76
3.67
4.17
4.20
Jul Aug Sep Oct Nov Dec 4.25
4.16
3.26
2.41
1.53
1.05
- 50 Watts * 0.61 DC system eff * 2.76 Hours = 84 WH per day (March)
- 84 WH / 12 volts = 7 AH @ 12 volts
http://www.solar-electric.com/wind-and-water-products/sodcwapu/shacdcwapu/sh80sedepuan/8000-443-136.html
Will use between 4-7 amps (roughly) depending on pressure and flow:- 7 AH / 4 amps = 1.75 Hours of use (average March day)
- 7 AH per day * 2 days use * 1/0.50 maximum discharge (for longer battery life) = ~28 AH @ 12 volt battery
Does this help?
Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset - 50 Watts * 0.61 DC system eff * 2.76 Hours = 84 WH per day (March)
Yes this helps loads. The pump will be on a timer coming on 3 times a day for 1 minute at a time. I'm always messing about with stuff and it drives our lass mad. Plus it's homebrew time so that's another thing to cheese her off. Thanks again.
- 626 Discussion Forums/Café
