Size of inverter needed
What size pure-sign-wave 12 volt inverter to run
10 laptop computers
3 Desktop Computers
3 Floor standing domestic fans
1 Internet Router
and 10 x 5 watt LED lights
  • PhotowhitPhotowhit Posts: 4,670Solar Expert ✭✭✭✭
    Too many variables, Desktops can run 150-1500 watts, floor fans 50-300+, Laptops from 25-200+
    Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites,  Midnite E-panel, Prosine 1800 and Exeltech 1100, ForkLift battery. Off grid for @13 of last 14 years. 1000 watts being added to current CC, @2700 watts to be added with an additional CC.
  • Mountain DonMountain Don Posts: 493Solar Expert ✭✭✭
    I don't mean to sound like a smartass but I would start by adding up the watts that are usually listed on the device power block or name plate.
  • capitanojulianocapitanojuliano Posts: 20Registered Users
    Yes you are right, this set-up is going to be charged by a mains battery charger and is a back-up system when there is a power outage. The frequency is such that probably even a 10 amp charger has enough time to re-coup the batteries.
    I shall be posing a new question which is an expansion of the previous topic.
    Unfortunately it will seem even more unspecific as to exact consumption.
    I thank you for your input thus far which is helping toward my provision of power in Cambodia.
