I need a way to have stable 13V power to some electronics with a narrow acceptable power band.
soilguy
Registered Users Posts: 3 ✭
Voltage from my batteries sometimes exceed the voltage limits of the electronics. Limits are 11.7-14.5V. I would like to somehow take my ALPS 130W 12V panel and upvert it to 24V, then use a DC-DC converter and go back down with regulated power somewhere in the above stated range. I have two 100ah AGM 12V batteries available for each installation. I am not sure how to accomplish this with the equipment available. I assume I would need a 12V charge controller (currently using genasun GV10 mppt) Maybe not, not sure how to proceed.
There are three basic switching type power supplies:
Boost: Takes a lower voltage and increases it
Buck: Takes a higher voltage and drops it
Buck-Boost: Can take a higher or lower input voltage and regulate to needed voltage
Something like this is what you are looking for:
http://www.amazon.com/DROK-Adjustable-Non-isolated-Buck-Boost-Transformer/dp/B00GWCC6S4
Switching power supplies do have noise on the output--Depending on your loads, this switching noise may or may not be an issue.
Thanks Bill,
So, I could use the existing power config of 12V and one of these buck-boost transformers to increase the voltage to what I need? What if the incoming voltage gets below my minimum of 11.7V? While this is not likely, it has been known to happen. BTW, I am not an electrician. -
I'm thinking that this may work a little better since it is going to be in an outdoor location.
http://www.amazon.com/gp/product/B017CNAL56?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=A2OCOGC9B25845
Looks very reasonable... Not currently available at Amazon.
- 626 Discussion Forums/Café
