WVO generator running 2 x 80A 24VDC alternators.
aus_fudsteraus_fudster Posts: 3Registered Users
Hi everyone,
Ive built a WVO diesel generator that i have running 2 80A 24VDC truck alternators, I want to use this to charge my 1550AH battery bank during low sun days. I have 3500kw solar panel setup which does well and uses 60A MPPT's.
My question is what kind of charge controller can i use for this to successfully charge the battery bank?
Any input would be much appreciated.
  • WaterWheelWaterWheel Posts: 254Registered Users ✭✭✭
    considering the fact that you're running an automotive type alternator a typical 24v voltage regulator should work.
    Conext XW6848 with PDP, SCP, 80/600 controller, and conext battery monitor
    18 SW280 panels on Schletter ground mount
    48v 790 amp/hr Crown battery bank
    If your were running  permanent magnet alternator like a wind or hydro turbine usually uses you'd then need a charge controller that sends excess energy to a load such as a heating coil.      Automatic alternators only produce electricity when the field in energized which is controlled by the voltage regulator.        Go to a car part shop, they should be able to set you up with a $25 controller.
  • aus_fudsteraus_fudster Posts: 3Registered Users
    Sorry should have said, I have a 12V battery bank. I currently have 24V panels that my MPPTs drop down to 12V.
    Would a 24->12v wind charge controller work for this?
    Could i use a solar MPPT CC as the voltage and current would be steady, as opposed to a wind/water generator which fluctuates. Would this work if i kept a couple of water heater elements running to pre heat the water going into my solar evaporator?
  • ThomThom Posts: 180Solar Expert ✭✭✭
    Hi everyone,
    3500 kW of solar panels !! Wow
    Thom
    Off grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator
  • inetdoginetdog Posts: 3,121Solar Expert ✭✭✭✭
    The MPPT front end of charge controllers may or may not play well with the 24V stiff (constant voltage) output of the alternators. If you can ask the CC manufacturer for their recommendation you could avoid costly damage.
    SMA SB 3000, old BP panels.
    Thom said:
    Hi everyone,
    Thom
    opps thanks for pointing that out..... 3500W (3.5kW)....
