Homemade Solar Generator
I decided I wanted to build my own, and "hobby" my way into a backup energy system. I don't want to debate batteries, I'm just going to go with 2 Trojan 105's for now because of their ubiquity an the pages and pages of info about them. What I'm unsure about is the charger/controller.
Most of the info that I find is too simplistic and is of no use or too technical and I can't understand it (and is of no use). What I want is a charger/inverter that I can plug into the wall (I have currently have plain old grid service) to keep it charged, but can add a few solar panels to as it grows (and I learn the language), and a small generator. Basically an RV system, without the RV. Do I need a charge controller? Is there a difference between a controller and a charger inverter, or is the terms interchangeable? And does MPPT come into play with this small system I'm looking at? I'm thinking I want to stay at 12 volts, and around a 2000 watt inverter.
Please discuss...
You always need a charge controller.
Get a Morningstar MPPT charge controller. That way you can be very flexible in panel voltage, you can use up to a "36 volt solar panel" (up to 75 volt open current voltage) to charge a 12 volt battery system.
Get a pure sine wave inverter. I have found a lot of devices don't like the cheap modified sine wave inverters.
I have moved away from modified sine. Typical affordable 12v pure sine inverters are usually around 900 to 1000 watts.
Sounds like you want something like I built:
http://ecorenovator.org/forum/solar-power/4544-home-made-solar-inverter-generator-hybrid.html
