Solar Edge & Sunny Island
rustysolar
Registered Users Posts: 3 ✭
Not really well. The SE will not respond proportionately to the throttle down signal from the SB, and so the SE will just keep cranking out power until the SB raises the frequency high enough that the SE shuts down completely for at least five minutes.
SMA SB 3000, old BP panels. -
I find the same using a Fronius Primo and Sunny Island with AC coupling. It just shuts off (fronius) when then battery gets up to a certain voltage - then its 5 minutes grid test, and another few minutes for other tests.... and repeat.
- 626 Discussion Forums/Café
