Pole Mounted PV Array Separation
James
Solar Expert Posts: 250 ✭✭
Is there a recommended distance between 2 sets of non-tracking pole mounted arrays?
Proposed location allows panels to be in line facing south with no restrictions...I'm considering about 12"-18" space between panel edges.
I don't think there will be an early morning shading issue, but looking for other opinions on this.
Re: Pole Mounted PV Array Separation
be carefull that when they are pointed east or west that one set doesn't shade the other otherwise you'd only need the clearance to have them turn without bumping into one another.
