How many solar panels
shubham
Registered Users Posts: 2 ✭
How many 24v 250w poly-crystalline solar panels are required along with 48v 20A MPPT for charging a 48v lead acid battery pack ?
please help....
Welcome to the forum,
The answer depends on the size (amphours) of the battery. The bigger the battery, the more solar panels you need to charge it.
When designing a battery based solar power system, you must have design criteria. In particular you must have a good description of the load. After all, the purpose of the system is to power the load.
Once you describe the load, the next step is to pick a battery. This is the most difficult part of the decision making.
Finally, after you pick a battery, you figure out how to charge the battery... solar, hydro, generator, wind, etc.
Tell us more about the purpose and location of the system. Location is often an important factor in design... will the batteries freeze? will they overheat? How much sun in the winter?
I believe you are in the Deoghar, JH, India area?
For 20 amp MPPT charge controller, the largest "cost effective" solar array would be around:- 20 amps * 59 volts charging 1/0.77 panel+controller efficiency = 1,532 Watt array "cost effective" maximum
- 20 amps * 1/0.05 rate of charge = 400 AH @ 48 volts largest suggested battery bank
- 20 amps * 1/0.10 rate of charge = 200 AH @ 48 volts nominal bank
- 20 amps * 1/0.13 rate of charge = 154 AH @ 48 volts smallest battery bank
- 1,532 Watt array / 250 Watts per panel = 6.1 panels ~ 6 panels
Note--You need to read the specifications of the MPPT charge controller, they have both a minimum and maximum Vmp-array voltages. In the US, our "higher end" MPPT controllers typically have a working Vmp-array maximum of around 100 VDC (Vmp rises as temperatures fall, so cold climates you have to "adjust" the maximum Voc voltage open circuit up) for a MPPT controller with a Voc input rating of ~140-150 VDC maximum input voltage.
edit : IF I use 150w 12v polycrystalline panels and size my battery bank to 48v 42Ah, then what will be the case ?
thanks for the comments -
Remember that "12 volt panels" in our case usually have Vmp in the range of 17.5 to 19.0 volts (36 cell panels):
- 59 volts charging * 42 AH * 1/0.77 panel+controller eff * 0.05 rate of charge = 161 Watt minimum
- 59 volts charging * 42 AH * 1/0.77 panel+controller eff * 0.10 rate of charge = 322 Watt nominal
- 59 volts charging * 42 AH * 1/0.77 panel+controller eff * 0.13 rate of charge =418 Watt "cost effective" maximum
- 150 Watt * 4 panels in series = 600 Watt array
Do you really need 48 volt battery bank? For a smaller system, a 12 or 24 volt battery bank may be a better choice. Instead of 4x 42 AH 12 volt batteries, you could use 2x 6 volt @ ~200 AH golf cart batteries. May be less expensive and golf cart (flooded cell) batteries are pretty forgiving (and fewer cells to check water levels, less wiring, but heavier copper wiring). Plus you can find more inverter and charge controller options.
Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset - 59 volts charging * 42 AH * 1/0.77 panel+controller eff * 0.05 rate of charge = 161 Watt minimum
- 626 Discussion Forums/Café
