schneider Mppt 60 150 & Mppt 80 600
11JAGAN
Solar Expert Posts: 34 ✭✭
hi,
Can i connect schneider Mppt 60 150 and Mppt 80 600 in parallel ? will it work smoothly?
Yes, you can home run each controller back to the battery bus and they will work fine together (assuming properly configured/programmed).
I do not know if the XanBus will allow them to synchronize/share information with an XW AC inverter.
Bill, there really is not any DC data to share with the inverter. I know you know this but people often forget that there are at least 2 chargers. One is AC powered in the inverter/ charger and the other is DC powered from the sun,wind,water or ? These two chargers are completely different and have different places to read/adjust there settings! Two chargers !
The xanbus has all the data from everything and it is shared and displayed on the system control panel, combox, or over the MODBUS. Outback works almost the same way.
To the OP, if you copy settings from one DC charger into the other DC charger thru xanbus, your life will be easy. We love easy!"we go where power lines don't" Sierra Nevada mountain area
- 626 Discussion Forums/Café
