Best angle for east and west panels?
softdown
softdown Solar Expert Posts: 3,821 ✭✭✭✭
I'm at 37 N Latitude if that matters. 37 degrees is a "broad rule of thumb" for southerly panels.
I just can't seem to recall the best year around production for east and west panels. PV watts has changed. Think I recall that it used to allow computations for easterly and westerly panels.
  • Vic
    The new NREL PV Watts will allow Azimuth, and Array tilt to be entered. You can run each array independently.
    And, here is some additional reading:
    http://solarpanelsphotovoltaic.net/find-best-solar-panel-angle-tilt-angle/
    Vic
  • softdown
    From the article and right off the bat: "In general a steeper slope is preferable during the summer as the sun will be higher in the sky."
    I think this may be poorly worded.
    Other than that, the article is pretty useful for orientation of south facing panels.
    Last years edition of PV Watts made it real easy to compute angles for east and west panels. I'll give it another look as it may simply be "buried" a bit now.
    EDIT: New edtion of PV Watts is likely better than last years...after you grow accustomed to minor changes.
    For me: Easterly panels should be ~15 degrees.
    Westerly panels should be ~ 35 degrees
    Westerly panels deliver ~15% more energy than Easterly panels
    CONCLUSION: Very worthwhile to do inputs for easterly vs westerly panels. This is somewhat intuitive....just thinking about it.
    Vic wrote: »
    http://solarpanelsphotovoltaic.net/f...le-tilt-angle/
    Vic
  • Vic
    softdown wrote: »
    soft..,
    Sorry about the Link, above ... last night, I did not more than abut 10 seconds to review what was written at that site, did not have the time, then.
    Yes, in general, the "information" could be more clearly written, and the quote that you pulled from there, is simply wrong for most of us on this planet.
    In general, for Summer months, the PV modules should be tilted less -- ie, be more flat. The correct tilt information is stated later in the text.
    There are a number of strategies in choosing the proper tilt for fixed-tilt arrays, based on what time of year one wants/needs the maximum amount of PV production. This tilt preference can easily change, when one discovers Air Conditioning, and so on.
    And, yes the newest PVWatts calculator, is actually somewhat better, in many regards, than was Ver. 2, especially considering the greater precision in Location and WX data, etc.
    Vic
