Adding panels, Can I add to the grounding ???
Photowhit
So I picked up 4 cheap panels that meet the specs of my current panels. Will add the to the top of my array where I have left the supports extended.
I was wondering if I can use the clamp bolts to add the grounding wire to the existing wire? I have a bunch I have salvaged off telephone pole grounds, I guess this is cool, I think I've always seen them use 2 on each combining with some space in between.
While I'm up there any suggestions about checking the continuity of the other grounding wires to the frame work of the existing panels?
  • zoneblue
    The lug and nut bolt solution i started with started to look a bit unsavory after 2 years, so replaced them with these
    http://www.solar-electric.com/gbdbtsopagrl.html
    They are holding up ok for now. A squirt of noalox wouldnt go astray maybe...
  • vtmaps
    Photowhit wrote: »
    My limited understanding of NEC is that equipment grounding conductors must be continuous, or if there is a splice the spice must be irreversible.
    Zoneblue, That is what I use on the panels, I'm referring to adding the grounding to my existing grounding wire.
    vtmaps, I have 2 runs now from the panels joined with my run from my power center at the grounding rod, The power company uses these clamps on their power poles,
    figured they would be fine, and I thought I had read something about continuous as well, maybe they consider these to make a continuous bond.
    The continuous bond, as I understand, is to make sure that nobody can disconnect the safety ground wire by unscrewing a bolt/wire nut/etc.
    So do I need to do another continuous wire?
    What do I need to do at the grounding rod, restrict access to the clamp?
    Dave Angelini Solar Expert Posts: 6,746 ✭✭✭✭✭✭
    True and very good to always keep in mind. Offgrid and high up on the array Photowit has an excellent item for making the connection. I doubt a school bus full of 7 year old's with tools will be stopping outside his array. I would verify resistance at the new connection to the GEC and rod at this time.
