Solar Panels For Grundfos 3sqf-2
HI,
THIS IS MY FIRST TIME ON THIS OR ANY OTHER FORUM. I OWN THE ABOVE PUMP. DO I NEED TO USE GRUNDFOS PANELS WHICH ARE A HIGHER VOLTAGE PANEL OR CAN I COMBINE OTHER 12V PANELS ? IF THIS PUMP DOES NOT WORK OUT, I DON'T WANT TO BE OUT THE MONEY FOR THE PANELS ALSO. MY HOUSE IS ON 24V.D.C. SOLAR SYSTEM AND I CAN ALWAYS ADD 12V PANELS TO MY EXISTING ARRAY. ANYONE OUT THERE WITH EXPERIENCE WITH THESE PUMPS?
THANKS
CHARLIE
CHARMAR123@AOL.COM
THANKS
CHARLIE
CHARMAR123@AOL.COM
Re: Solar Panels For Grundfos 3sqf-2
Any panel that gives you enough voltage and watts.
And ALL CAPS is considered shouting.
