look before leap
froggersix
froggersix Solar Expert Posts: 35
i thought i had a great plan to go off grid but found out after i bought the place theres not enough sun even if i cut down all the trees in winter. so now i have to think again and will probably sell and move as now i have to run generator whenever i need electric and thats no good. i did not buy panels and stuff first though so thats good.
plan everything first before you buy anything!
    Dave Angelini Solar Expert Posts: 6,749 ✭✭✭✭✭✭
    Your plan can always be changed and made to work! While location and physical layout are important, given enough time and money, a beautiful location can be made to work very well. In fact, it has never been easier in the offgrid world!
  • petertearai
    petertearai Solar Expert Posts: 471 ✭✭✭✭
    if you have enough land put panels on a frame, Often easier and better than roof mount .
  • froggersix
    no cuz i do't have huge amounts of money to buy more panels than fit the property there just isn't enough sun in winter to do this so i rethink the whole deal. should figure this out before buying the land!
    froggersix wrote: »
    Well, each person must know their limitations. It can be done but it really helps if you love the place.
    Where is the property located? There are a number of posters that live " North of 60* " on the board and they have designed systems that work..
  • Ethan Brush
    Ethan Brush Solar Expert Posts: 235 ✭✭
    You could set some poles or posts and get your array up high. I think you would be surprised with what taking down a few trees and getting your array 20 feet up will do. Winter can be tough off grid. Even the "pros" may run a generator frequently.
