Forum Update - Can not edit signature to add system components
Anawa
Solar Expert Posts: 225 ✭✭✭
The subject says it all. When I went to my account settings to include my system components, after filling in the info, got an error message. Tried multiple times. Needs to be de-bugged.
Anawa
Anawa
Paul
in Georgia
System 1: PV- 410w Evergreen, Mppt- Blue Sky Solar Boost, Batt - 225ah Deka AGM, 12v led house lighting,
System 2: PV- 215w Kyocera, PWM - Morningstar PS30, Batt- 225ah Deka GC's, 12v led house lighting, Dankoff 12v water pump,
System 3: PV- 1.5kw Kyocera, Grundfos 11 SQF well pump, 3000 gal above ground water storage, dom water & irrigation,
System 4: PV- 6.1kw Kyocera, Mppt- Outback FM80-2ea, Inverter- Outback FX3648-2ea, Batt- 804ah GB traction, Grundfos BMQE booster pump 240v, Mitsibushi mini-splits 240v, 18k and 15k
in Georgia
Here is the message: "{"errors":"unexpected_error","Required argument missing: signature"}"
Also, screen freezes and only back button gets you back to user setting screen.
AnawaPaul
in Georgia
System 4: PV- 6.1kw Kyocera, Mppt- Outback FM80-2ea, Inverter- Outback FX3648-2ea, Batt- 804ah GB traction, Grundfos BMQE booster pump 240v, Mitsibushi mini-splits 240v, 18k and 15k -
Anawa,
How long is your signature?
Anyway, if you want, post your signature here (if you cannot edit the one I put in), and I will update it for you.
B.B. - Apparently my signature was too long. As you can see, after some trimming, it now fits. Thanks.
AnawaPaul
in Georgia
Anawa, where is the sig function?
Thanks -
SdKev - Go to your user Account and scroll down about half-way and you will see a check box enabling signature. Within the same space, you will see Edit Signature. Use this function to add/edit your sig.
AnawaPaul
in Georgia
- 626 Discussion Forums/Café
