Sizing MPPT Controller??
ftm1776
Registered Users Posts: 3
I want to add a couple of panels to my system.
Total watts: 540
Voltage: 24 volts
Nominal current: 22.5 amps
Can I get some comments on using a 20 amp MPPT controller, assuming 85% efficiency to the power bus?? So usable current would be about 19.15 amps
Total watts: 540
Voltage: 24 volts
Re: Sizing MPPT Controller??
Every brand and model is a bit different. gives us a brand and model and look at the specs for the 20 A and 30Amp models too,
30 amp makes to look at are: MidNite Kid and Rogue
Morning star for the 20 amps
Vmp-array? Vbatt=24 VDC?
