Help with 2 x 250 watt panels
marky
Registered Users Posts: 4
Hi i have two 250watt solar panles and i am only getting 170 to 190 watts in full sun could anyone plz help
Re: Help with 2 x 250 watt panels
Assuming your battery bank is low and needs charging, the charge controller is in MPPT/maximum current mode, you are measuring current in the middle of day, etc...
How are your panels wired? In series or in parallel?
What is the Vmp/Imp of the panels? What is the voltage measured at the Vpanel input the the charge controller?
Also is this total for both panels?
What stage is your charge controller in? Bulk, Absorb, Float?
What panels do you have?
How are you measuring the wattage produced?Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Have you retightened all connections as well
Hi thank you for getting back to me we have snow at the min so i cant get on the roof to get the spec soon has the snows gone i will get back to u all
thanks mark -
In the mean time you can re-torque all interior connections from the disconnect to the cc and batteries:cool:
- 626 Discussion Forums/Café
