AC Fridge on Solar
gm_navy
Registered Users Posts: 1
Hi Folks,
I have recently upgraded my rooftop grid-tied solar plant in India from 1000Wp to 2000Wp.
I wish to run my 220 V 400w AC fridge off this plant.
I expect a starting current of 7-8 amps. Will the excess current above solar panel output get drawn from the grid without difficulty ?
Ganesh
Ganesh
Re: AC Fridge on Solar
If your solar inverter is tied to the grid, and the fridge is plugged into an outlet that is grid powered, then you should be fine, if I understand your configuration.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 626 Discussion Forums/Café
