can I use this panel for 24 volts
dolcesails
Registered Users Posts: 11 ✭✭
Hi guys,
This is an 12volt ESC 120 FA2 Evergreen panel if 2 are wired together will I get 24 volts and if so how, I have posted a question about a boat project awhile back and was told if I could do it in 24 volts I'd be better off. Thanks, Nick.....
Re: can I use this panel for 24 volts
Simply connect the + from one panel to the - of the other panel.
Then the remaining - from one panel and the + from the other panel goes to your charge controller (or breaker/fuse).Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html
- 626 Discussion Forums/Café
