I want to utilize both legs of my generators split output. Transformer?
Dan_
Dan_ Solar Expert Posts: 61 ✭✭✭✭
I have a 3200W 240v generator and an Outback FX3048 (120v input). Id like to balance the generator and utilize both legs of its output. I see Outback has a transformer but its rather pricey. Am I barking up the right tree? Any other options?
Thanks in advance
  • vtmaps
    Re: I want to utilize both legs of my generators split output. Transformer?
    Dan_ wrote: »
    You have correctly figured out the solution and the price to pay. --vtMaps
    BB. Super Moderators, Administrators Posts: 33,433 admin
    There are a few 120/240 VAC gensets that either have a 120 VAC only mode (switch on the panel), or can be reconfigured internally to run the two 120 VAC circuits in parallel (full power in 120 VAC only mode).
    This may give you some idea on how to proceed--If you want to hack up your generator (vs the cost of the Outback transformer).
    http://www.utterpower.com/synchronous-generator-basics-simple-guide-to-rewire-your-head/
