Known Software "bug" in search--Does not affect anything.
BB.
Super Moderators, Administrators Posts: 33,422 admin
Originally Posted by Steven Lake
Hi, you've got a code boom on your forum software.
Warning: Declaration of vBForum_Item_SocialGroupMessage::getLoadQuery() should be compatible with that of vB_Model::getLoadQuery() in ..../packages/vbforum/search/result/socialgroupmessage.php on line 24
Steven Lake noticed the above (several times) lines in the Search function window (at very top).
Rick, our Admin from NAWS, looked through the software support bulletins and found that this is a known bug in the version of software we are currently running.
Once Rick has finished migrating the NAWS web store (hopefully in the foreseable future--Spending lots of time the NAWS website migration)--He will be back here to perform an upgrade of the forum software (which is supposed to fix this bug).
Thank you Steven for letting Marc/Cariboocoot know about the problem.
And thank you Rick and NAWS for supporting this forum.
Re: Known Software "bug" in search--Does not affect anything.Steven Lake noticed the above (several times) lines in the Search function window (at very top).
I generally use a Google search with the site:forum.solar-elecrtic.com qualifier. Admittedly it does not have access to all of the internal metadata of the forum for use in search strings, but it sure does the job if you are just looking for particular content.SMA SB 3000, old BP panels.
- 299 In the Weeds--Member's Choice
