Capping generator input limit
Freewilley
Solar Expert Posts: 228 ✭✭
I know that somewhere on my Mate I can set the draw from the genny....can you remind me where that is? Currently it is set at 1700 watts total, and I would bump that up to maybe 2400...
In the same area, what is the maximum power input for my 4 S550 (12 volt wired) batteries? I think it is somewhere around that 1700 watts but I know you experts have a formula....
Mate, VFX 2812, FM 60 & MX 60, 2 Full River AGM 400 6v, 1400 watt Solar Array, Yamaha 3000iSEB inverter gen
12 volt Flojet water pump
off grid summer home in northern Ontario
Re: Capping generator input limit
Main Menu Setup> Input > Gen or Grid > down > choose amp limit. Setting the Charger limit is, Advanced > FX> Charger. That is different from AC input limit.
- 626 Discussion Forums/Café
