these things work? (Energy Controller Unit (KVAR PU1200))
andersondiaz
Registered Users Posts: 22 ✭✭
I do not know if it's a topic to discuss in this forum.
*but they say we can save on our electricity bill.
ask me, these things really work?
http://www.kvarnational.com/Patent_Certifications.html
http://www.kvarnational.com/NASA.html
Re: these things work? (Energy Controller Unit (KVAR PU1200))
They really work at correcting PF. And they don't change your bill one bit, because you are not billed for PF. It's a rip-off.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
And any PF correction equipment which does is not switched in and out of the circuit along with the major low PF loads (A/C or heat pump compressor motors for example) will likely overcorrect when the equipment is not running and so cause a lower power factor at those times. End result is that it still does not change your bill, but it also does not decrease your very small I2R losses a much as their analysis indicates either.
I have talked to a few honest electrical contractors who got distributorships and ended up dropping out and refunding the customers' money on their own to maintain good will.SMA SB 3000, old BP panels. -
From 2010 discussion about same type of product:
Power Save 1200 Capacitor
- 626 Discussion Forums/Café
