not getting enough watts from solar panel
solarpowernovice
Solar Expert Posts: 134 ✭✭
I have one solarworld 270 watt solar panel hooked up with 40 feet of #10 awg cable and I am only seeing 190 watts on the midnite classic display. The solar panels specs are 39.2V Voc 9.44A Isc, it is in full sunlight laying flat and it is noon... is my wire run too long or is it something else?
these are the cables i bought http://www.solar-electric.com/30fomc4so2ex.html but the wire is a silver color not copper...
Re: not getting enough watts from solar panel
There are two main factors that affect a solar panel's output: insolation and load. People tend to ignore that second one. It will not put out full power (do not expect 270 Watts; more like 207 on average) unless it is fully illuminated and fully loaded. The closer the battery is to charged the less power you get (unless you turn on all the loads). So how low is the battery? -
BTW Isc and Voc are irrelevant to power output.
Watts = Imp * Vmp. In this case I would hazard 8.7 & 31.
Nor does that mean you will see that on the controller's display, as it will pick its own best power point which is not necessarily the panel specs. -
the batteries were at 12.5v when i started charging them ( around 10 am )and this is 75% state of charge according to the manufacturers website. I have four 232 amp hour 6v batteries in 12v configuration. the inverter has been turned off the whole time and now its saying 200 watts on classic display. -
A single 270 Watt panel isn't enough for 232 Amp hours @ 12 Volts. You knew that already.
But you ought to be able to max out the panel easy enough by turning the inverter on and adding some loads. It doesn't take much to reach 200 Watts. -
yes i knew it wasn't enough panel to get them to 100% today (i hope this isn't harmful to the batteries) I just wanted to make sure I wasn't getting some kind of crazy voltage drop that i shouldnt be. I will turn a load on and see what happens... I am trying to mount my panels to the trailer but am having problems so for now i only have 1 panel hooked up becaus im too lazy to move the others. thanks. -
40 feet of 10 AWG at 30 Volts & 9 Amps ... about 1 Volt drop at most.
BTW the silver colour is because it is pre-tinned. If you look really carefully at a cut end you can see the copper colour underneath. You may need a magnifying glass. -
Re: not getting enough watts from solar panelsolarpowernovice wrote: »... I am only seeing 190 watts on the midnite classic display. The solar panels specs are 39.2V Voc 9.44A Isc, it is in full sunlight laying flat and it is noon...
Sounds about right! Panels have a Normal Operating Cell Temperature (NOCT) value, for this panel it's Right at 195 watts;
Here's a spec sheet.
I would think your 270 watt panel is marginal for 235 Ah 12 volt battery bank, I lived for quite a while on 200 watt array and a 12v 215ah bank, but you have 470ah, 2 strings of 235 ah batteries.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
yes I have 2 more of the 270 watt solar panels, I just haven't permanently mounted them to my trailer yet. They are too big and heavy for me to carry around every time i want to charge my batteries, this will be solved as soon as i have them mounted then i can shorten my wire run too. Thanks for the clafication guys... I thought the solar panels were supposed to actually say close to 270 watts a piece on the charge controller. -
If thieves didn't breaking into my building on my land and steal all my stuff I wouldnt have to worry about making this system portable. My original plan when I bought all the components for my system was to put the solar panels on the buildings roof and all the components inside, but I cant be there all the time to guard my stuff too bad its illegal to set up boobie traps lol that would've been much easier and cheaper... -
Re: not getting enough watts from solar panelsolarpowernovice wrote: ».....I thought the solar panels were supposed to actually say close to 270 watts a piece on the charge controller.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 626 Discussion Forums/Café
