Testing batteries with load tester
jcheiljcheil Posts: 719Solar Expert ✭✭✭
Can you test individual batteries in a string with one of these without disconnecting all the interconnects?
  • CariboocootCariboocoot Posts: 17,615Banned ✭✭
    Re: Testing batteries with load tester
    Yes, as long as the string isn't connected to anything (no load/charging on the terminus).
  • ILFEILFE Posts: 364Solar Expert ✭✭
    jcheil
    How much are those load testers nowadays, in the US?
    Paul
  • jcheiljcheil Posts: 719Solar Expert ✭✭✭
    ILFE wrote: »
    jcheil
    $19.99 right now at Harbor Freight.
  • mike95490mike95490 Posts: 7,783Solar Expert ✭✭✭✭
    You need to "test" each battery for the same amount of time, or you will have to equalize the bank afterwards.
  • BB.BB. Posts: 27,681Super Moderators admin
    Usual battery bank safety... Wear a face shield and some sort of gloves to protect against acid/flash burns. Assume that at some point, the clamps will generate some sparks. Ventilate the battery box/bank well, cover cell caps with a damp towel or something similar.
    Sounds like over kill--But I would rather everyone be safe rather than sorry.
    What is the ratio for the mixture to neutralize the acid?
    1 pound of baking soda to 1 gallon of water? Am I correct there?
    Paul
  • westbranchwestbranch Posts: 5,082Solar Expert ✭✭✭✭
    this little clip on SoC just came in http://www.youtube.com/watch?v=WWzC_yaMHkE&feature=youtu.be
    may be of use..
    2 x Cisco WRT54GL i/c DD-WRT Rtr & Bridge, Hughes1100 Sat Modem
    ILFE wrote: »
    Much less, and applied in several batches. Each reaction causes heat, so too much "base" mixed with "acid" gets you thermal burns in addition to the acid burns.
  • PNjunctionPNjunction Posts: 762Solar Expert ✭✭✭
    Don't be too alarmed if things get a little smoky / burnt smelling the first few times you use it.
