monitoring perameters on solar power genration
AJITNAYAK
Registered Users Posts: 11 ✭
Dear all.
I am new to solar firm. I need some information on Solar monitoring perameter.
In any power generation What kind of parameter can be views by remote monitoring solution.
As i attached in above image, What are the list of perameter expected to view
I WOULD LIKE TO LIST OF COMPONENT PERAMETER INVOLVED IN EACH LIST
Dear all.
Re: monitoring perameters on solar power genration
Are you looking for smaller/off grid systems with integrated battery/solar/load monitoring?
Or a large Grid Tied / Industrial type application?
The off grid installation is all about power management.
The on grid system is about performance to specifications, fault detection, possible remote control of output/power factor by utility, etc.
i am looking for both type of system . With single solution -
You probably will not find a single solution---Except for some non-OEM systems that people have put together. Large GT systems and small Off Grid systems just have almost nothing in common (functions, hardware, usage, etc.).
http://www.greenhousepc.com/blog/ (one of the occasional posters on this forum, and does a lot on other off grid system forums).
