Off grid battery web monitoring
Glamsland
Registered Users Posts: 8 ✭
Hello!
Do any of you guys using a web based monitoring system for your off grid solar system?
Im thinking about something like the midnite monitor app.(but idont have a midnite CC..). And others..
I have been thinking about the www.watmon.com system , looking easy to install, but i like better the "midnite look" On the screen....
Any experience. Good or bad?
Runar
Runar
Re: Off grid battery web monitoringHello!
Runar
It depends on what kind of system you have. Outback won't talk to Midnight and visa versa so if you have mixed components you either end up with 2 different pieces of software or trying to find one that can read both devices.
If you are handy with computers, here is a fork of a really good one for Outback products.
I am currently working on this one with another guy who forked it from the original. It's web-based so it will run on pretty much anything.
Source Code: https://github.com/instanttim/monitormate/
He always runs the master branch on his own site: http://finleyridge.com/power/ so you can see up to the minute results.Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html
